Global variables
index.php sets up these globals before it runs a controller. Declare the ones a module needs:
global $mysqli, $redis, $session, $settings;
See Modules/input/input_controller.php for a typical list.
$settings
Settings array. process_settings.php merges settings.ini (or settings.php) over default-settings.php. See example.settings.ini for the sections.
$path
Base URL of the Emoncms install, for example http://localhost/emoncms/. view() also passes it to every view.
$mysqli
A mysqli connection to the Emoncms database, from $settings['sql']. Use prepared statements.
$redis
A Redis instance when $settings['redis']['enabled'] is true, otherwise false. Emoncms uses Redis to cache input and feed metadata and API keys, and to buffer feed writes on low-write systems. Code that uses Redis must work when $redis is false.
If Redis is enabled but the connection fails, index.php stops with an error. prefix, auth and dbnum in $settings['redis'] set the key prefix, password and database number.
$route
A Route object, defined in route.php. For the URL:
http://server/controller/action/subaction/subaction2.format?name=value
the properties are:
$route->controller // controller
$route->action // action
$route->subaction // subaction
$route->subaction2 // subaction2
$route->format // format: html (default), json, text, md or csv
$route->method // GET, POST, ...
$session
Array describing the current session. Set by User::emon_session_start() for a web login, or by User::apikey_session() for an API key.
Key |
Meaning |
User id |
Username. |
1 if the session can read |
1 if the session can write |
1 for an admin session |
Language. |
User timezone |
Page to open after login |
Gravatar address |
1 if logged in with the remember me cookie |
Email verification state, when email verification is on |
1 for an API key session |
Set when a page is viewed through a public username URL, such as |
$user
A User object from Modules/user/user_model.php. Use it for login, API keys and user details such as username, email, language and timezone.
$log
An EmonLogger. Create one per file with new EmonLogger(__FILE__). Logs go to emoncms.log in $settings['log']['location'].
$param
A Param object from param.php. Reads request parameters, including decrypted parameters from an encrypted input request.
Translations
tr() and ctx_tr() read $GLOBALS['language'] and $GLOBALS['translations']. See Developing a new module.
