Emoncms CSS guide
How to style pages in emoncms core and modules. Emoncms uses Bootstrap 5.3 with an emoncms theme and a small set of shared components. New pages and modules start from the patterns here.
Converting Bootstrap 2 code: see bootstrap5-migration.md.
Contents:
  1. Overview
  2. Principles
  3. Adding CSS to a module
  4. Colours and tokens
  5. Light and dark
  6. Base styles
  7. Page families
  8. Setup page components
  9. Reference pages
  10. Apps
  11. Bootstrap build
  12. Planned
1. Overview
Every page loads, in this order (Theme/theme.php):
File
Contents
Lib/bootstrap5/css/bootstrap.min.css
Bootstrap 5.3.8, a reduced build (see Bootstrap build)
Theme/css/bootstrap5-theme.css
Palette and tokens, element look, buttons, component sizes, page shell, reference page components
Theme/css/bootstrap2-icons.css
Glyphicons (icon-*)
Theme/css/emoncms-base.css
Colour schemes, sidebar sets, shell details
Theme/css/menu.css
Top menu and sidebar
Theme/css/panel.css
Panel component
Theme/css/group-list.css
Group list and sticky list toolbar
Theme/css/autocomplete.css
Autocomplete fields
Theme/css/svg-icons.css
SVG icons (svg-icon-*)
JS: jQuery, Theme/js/emoncms.js (helpers such as list_toolbar()) and Lib/bootstrap5/js/bootstrap.bundle.min.js (Bootstrap with Popper, at the end of the page). Bootstrap plugins have a jQuery bridge, so $(el).modal('show') works.
Apps also load Modules/app/Views/css/app-kit.css.
2. Principles
  • Use a Bootstrap class or a shared component before writing page CSS. A new shared component goes in this guide.
  • Colours and shared values come from the variables in bootstrap5-theme.css, which have a light and a dark set. Page and app CSS do not set fixed colours. Exceptions: a component that sets both its background and its text, such as a pastel badge, and colours on the coloured top bar or the log window.
  • Colours carry meaning: green is fresh or OK, orange is a warning, red is stale or destructive. An energy source has the same colour in every app.
  • Page CSS goes in a .css file, not a <style> block. Inline style attributes only for values set from JS.
  • Keep CSS small. Remove a rule when its markup goes.
  • Page titles are h3.
  • Load page CSS and JS with load_css() and load_js() from core.php. The loaders add the file time to the URL, so browsers fetch the new file after an update. Do not use <link> or <script> tags with a fixed ?v=.
  • Put the stylesheet beside the view, for example Modules/sync/sync_view.css.
  • Prefix page classes with a short page name (net-, bk-, cfg-), so they do not clash with Bootstrap or other pages. Avoid Bootstrap names such as modal-content or accordion-body for page classes.
  • Read colours from variables: var(--bs-primary), var(--bs-border-color), var(--ec-text-muted). A new shared colour goes in both sets of the theme as --ec-*.
  • A Bootstrap class that is new to the codebase may be missing from the reduced build. Run node scripts/bootstrap5/build.mjs --check and rebuild if it lists the class (see Bootstrap build).
All colours and shared values are at the top of bootstrap5-theme.css, in three blocks. Components read them, so a look change is an edit there.
Block
Contents
:root, [data-bs-theme]
Values shared by both modes: button colours, type, shape, spacing, energy colours, and aliases such as --bs-link-color. On every theme root, so aliases take the colours of that root’s mode.
:root, [data-bs-theme="light"]
Light set
[data-bs-theme="dark"]
Dark set. Primary #44b3e2, surfaces #2e2e2e, text #ccc, borders #3f3f3f.
The light and dark sets declare the same variables. A new colour goes in both.
Use the Bootstrap name where the role is the same, and the --ec-* name otherwise.
Role
Variable
Accent (links, primary buttons, focus, active items)
--bs-primary, --bs-primary-rgb. #2a8fc7 light, #44b3e2 dark.
Accent hover and border, active
--ec-primary-dark, --ec-primary-darker
Accent tint
--bs-primary-bg-subtle
Text
--bs-body-color, --bs-emphasis-color (strong), --ec-value-color (values and table cells)
Secondary and muted text
--ec-text-secondary, --ec-text-muted, --bs-secondary-color
Surfaces
--bs-body-bg, --bs-secondary-bg, --bs-tertiary-bg
Borders
--bs-border-color, --ec-input-border-color, --ec-divider
Panel and group list headers
--ec-header-bg, --ec-header-hover-bg
Row hover
--ec-row-hover-bg
Group list
--ec-list-row-bg, --ec-list-selected-bg, --ec-list-selected-hover-bg, --ec-list-status
State colours
--bs-<colour>-rgb for text, --bs-<colour>-text-emphasis, -bg-subtle and -border-subtle for alerts, row tints and tags
Coloured buttons
--ec-btn-<colour>, -dark, -darker; default button --ec-btn-default-*
Code
--bs-code-color, --ec-code-bg, --ec-code-border
Other components
--ec-highlight, --ec-highlight-soft (inset line and text shadow, transparent in dark), --ec-table-striped-bg, --ec-form-text
Energy (apps)
--ec-energy-use, -use-light, -solar, -import, -export, -battery, -direct, -wind, --ec-energy-text for text on them
App surfaces
--ec-app-panel-bg, --ec-app-box-bg, time bar blue --ec-app-nav-rgb
Extra pastel pairs
--ec-purple-*, --ec-orange-*
--border, --bg-body, --font-* and --radius-* are also available.
Colour schemes: emoncms-base.css holds the scheme classes (.theme-*), which set the top menu colours as --bg-menu-top and related variables, and the sidebar sets (.sidebar-dark, .sidebar-light). A component that should follow the scheme reads these, as the sticky list toolbar does with --bg-menu-top-active.
5. Light and dark
Colour mode uses the Bootstrap 5.3 attribute data-bs-theme.
  • A page or app turns dark with data-bs-theme="dark" on its root element. Bootstrap and emoncms components inside it follow the variables, so they work in both modes.
  • [data-bs-theme] also sets the text colour, as Bootstrap sets it on body only.
  • The API pages, Network, the app config panel and the dark apps set dark. Light apps set light. Setup pages use the default light set.
  • The page background and footer sit outside the page root. The app kit and the reference pages set them to fixed dark values when a dark root is on the page.
  • To check a component in both modes, render it inside a data-bs-theme="dark" wrapper.
6. Base styles
The theme keeps the emoncms look where the Bootstrap 5 defaults differ.
Elements:
  • Headings bold with 10px margins and the emoncms sizes. Links underlined on hover only. 10px paragraph margin.
  • Lists indent by a 25px margin with no padding. .nav has no margin.
  • dl top margin, dd bottom margin, legend float and hr opacity as before the reboot. code and pre styled from the tokens.
  • The link hover rule uses a:where(:hover, :focus), so .btn, .nav-link and .dropdown-item keep no underline.
  • Table cells and links without href inherit their colour.
Change the element look in the theme base section, not with utilities on each page.
Differences from stock Bootstrap 5:
  • form-control and form-select are compact: 14px text, 4px 6px padding. Width classes set fixed widths (see Forms).
  • .input-group is inline and sized to its content. A full width group needs d-flex w-100.
  • Buttons: btn-default is the plain grey button. btn-xs is an extra small size. Coloured buttons use the emoncms palette. btn-outline-primary is a tint of the accent.
  • Badges: badge has the compact label look. Linked badges (a.badge[href]) are darker.
  • Tables have the emoncms cell padding and borders, and row tints (table-success and the like) without stripes.
  • Alerts have the emoncms padding.
  • Modals are 560px wide, 10% from the top, body capped at 400px with scrolling, grey footer, full width with a 20px margin below 768px.
  • hide sets display: none without !important, so jQuery .show() can undo it. Bootstrap’s d-none cannot be undone from jQuery.
  • main.content-container has display: flow-root and width: auto, as it sits beside the sidebar.
Bootstrap 5 points to keep in mind:
  • Every element is box-sizing: border-box. A width or height includes padding and border. Use box-sizing: content-box on a rule that needs the width to exclude them.
  • Utilities are !important. A page rule cannot override them.
  • .row > * gets gutter padding. Use row g-0 for columns with their own padding.
  • .btn-group > .btn is flex: 1 1 auto. Stop buttons stretching with a two class selector. Add text-nowrap where buttons in a narrow group would wrap.
  • .dropdown-toggle draws a caret with ::after. Hide it where the design has none.
  • .badge:empty is hidden. A badge used as a dot needs display: inline-block.
  • btn-link is underlined.
7. Page families
Family
Purpose
Look
Examples to copy
Setup pages
Managing things and settings
Light, grey and white, in the emoncms shell
Inputs, Feeds (lists), My Account, Post Process, Schedule, Admin (panels)
Apps
Dashboards for the household
Dark or light, chosen per app
MyElectricFlow (dark), MyHeatpump (light)
Reference
API documentation, network setup
Dark
API help pages, Network
The login page (Modules/user/login_block.php) sits outside the families. It is a light card on --bg-body-login, with the logo in a header in --bg-menu-top, so it follows the colour scheme.
A setup page uses one of two layouts under a page header.
List layout. For pages that list things: feeds, inputs, devices. Rows grouped by node or tag, collapsible, with selection and a sticky toolbar. Examples: Inputs, Feeds, Devices, Sync.
Panel layout. For settings, forms and tools. Examples: My Account (key and value rows with inline edit), Post Process and Schedule (panel table and panel form), Email Reports (tabs and switches), Admin info (compact rows, status tags), Backup, Graph.
Panel page
panel-page on the page root: grey page background, content 1150px wide, bottom padding, 1rem between panels. A page that needs another width sets max-width on main.content-container:has(.its-page). Panels can sit in a Bootstrap grid (row g-3 > col-lg-6).
Panel
Theme/css/panel.css.
<div class="panel">
    <div class="panel-header panel-header-static">
        <span class="panel-accent"></span>
        <span class="panel-name">API keys</span>
    <div class="panel-row">
        <div class="row-key">Read key</div>
        <div class="row-value">...</div>
        <span class="row-action svg-icon-content_copy" title="Copy"></span>
Rows sit straight in the panel. Other content goes in panel-body.
Class
Role
panel
Container
panel-header
Header row, pointer and hover
panel-header-static
Header that only labels the panel, no pointer or hover
panel-accent
Accent bar before the name, panel-accent-danger for destructive actions
panel-name
Title
panel-badge
Count or state beside the name. Also works outside a panel header.
panel-body
Content with padding
panel-controls
Strip of fields and buttons
panel-row
Key and value row: row-key, row-value, row-note, then row-action icons and buttons. is-editing while an inline edit is open.
row-action
Icon action, shown on row hover and always on touch screens
panel-form
Stacked form in the panel body: panel-field blocks with a form-label above the field, then panel-buttons
panel-empty
Message in place of an empty table
table in a panel
Uppercase grey column heads, row hover. col-primary and col-secondary on cells, panel-actions on the buttons cell, is-editing on the row open in the editor.
panel-table
Wrapper for a table that scrolls sideways. The page sets the table min-width on narrow screens.
Inline edit replaces the value with the field and Save and Cancel buttons.
Group list
Theme/css/group-list.css. Column widths are set per page on the group-list grid, with data-col on each cell.
Class
Role
group-list
Grid container
group-list-group
One node or tag
group-list-header
Group row, collapsed when closed
group-list-chevron
Arrow in the header select cell
group-list-name
Group name
group-list-rows > group-list-rows-inner
Collapsible wrapper, is-expanded when open
group-list-row
Item row, selected when ticked
group-list-cell
Cell
Status: --status-color on a header or row sets the stripe on its right edge. Time since update in green or red text.
Sticky list toolbar
div.list-toolbar with btn btn-default icon buttons, then the filter field or page actions pushed right with ms-auto. An empty div.list-toolbar-sentinel goes above it. Once both are rendered, the page calls:
list_toolbar(sentinel, '.list-toolbar');
The toolbar sticks under the top menu with a bar in the menu colour (is-sticky).
Buttons
  • btn-default for ordinary actions, btn-primary for the main action of a panel or modal, btn-danger for delete and other destructive actions.
  • One primary button per panel or modal.
  • btn-sm and btn-xs for smaller buttons. Keep a variant class on every btn, including when JS swaps variants.
  • Icon buttons: btn btn-default holding an svg-icon-*.
Labels and tags
  • Status labels: badge bg-success, bg-warning, bg-danger, bg-secondary.
  • Pastel tags (method, access, state): badge px-2 bg-success-subtle text-success-emphasis, with primary, secondary, info, warning, danger, purple or orange in place of success. No page CSS is needed. The theme sets the subtle and emphasis colours in both modes and adds the purple and orange utilities.
  • Examples: feed engine badges, admin tags, user avatars, API method tags.
Forms
Every text input, select and textarea has form-control or form-select. A bare field shows as a plain browser field.
Need
Markup
Field with a fixed width
form-control input-220, form-select input-165
Widths
input-75, input-105, input-165, input-220, input-285, input-545, input-auto (select sized to its options)
Full width
form-control alone
Label above
label.form-label (block, 5px below)
Help text
form-text
Label or unit beside a field
input-group > input-group-text + field. The field needs a width class.
Stacked fields
mb-2 on each
Invalid
is-invalid on the field, text-danger on the help text
Colour
form-control form-control-color
On and off setting
form-check form-switch
Checkbox and radio
Native field, drawn in the accent colour with accent-color
Monospace
font-monospace
  • Width classes set the total width (padding and border included), display: inline-block and vertical-align: middle. They apply only together with form-control or form-select.
  • input-285 and input-545 go full width below 768px, except in an input group.
  • Readonly fields keep the grey background.
  • A page rule that sets a select’s height must set line height to the height less padding and border, or the text sits low.
  • A page rule such as .x input[type=text] also reaches fields inside components such as the date picker. Use a child selector.
Date picker
Lib/js/DateTimePicker.js with Theme/css/datetimepicker.css.
  • Vue: <date-time-picker v-model="start" @change="reload"> inside an .input-group. It renders an input, a calendar button and a dropdown menu as children of the group.
  • Other pages: DateTimePicker.attach(input, { value, onChange, buttonClass }) adds the button and menu after an existing input in an .input-group. The input keeps its id, value and events, and gets a change event when a date is applied. Returns getDate() and setDate(date). setDate does not call onChange.
  • Values are local time, YYYY-MM-DD HH:MM:SS. DateTimePicker.parse and DateTimePicker.format convert to and from Date.
  • The menu uses Popper with fixed positioning, so a scrolling modal body does not clip it.
Modals
<div id="x" class="modal" tabindex="-1" aria-labelledby="xLabel" aria-hidden="true" data-bs-backdrop="static">
    <div class="modal-dialog">
        <div class="modal-content">
            <div class="modal-header">
                <h3 id="xLabel" class="modal-title">Title</h3>
                <button type="button" class="btn-close" data-bs-dismiss="modal" aria-label="Close"></button>
            <div class="modal-body">...</div>
            <div class="modal-footer">...</div>
  • Open and close with $(el).modal('show') and $(el).modal('hide'). Events are shown.bs.modal and hidden.bs.modal.
  • .modal is the full screen overlay and .modal-dialog the box. Set the width with --bs-modal-width on the modal. Position and margin go on .modal-dialog, border and radius on .modal-content.
  • JS that reads the box position reads .modal-content.
Other Bootstrap JS
  • Collapse: data-bs-parent goes on the .collapse element, not on the toggle.
  • data-bs-toggle="button" toggles active before a page click handler runs, so the handler sees the new state.
Icons
  • New code uses SVG icons: <span class="svg-icon-wrench"></span>. They are CSS masks in the text colour, so they follow the mode and the button colour. The set is in Theme/css/svg-icons.css. A missing icon is added there.
  • Glyphicons (icon-*, icon-white) still work but are to be replaced (see Planned).
9. Reference pages
The API pages, the Network page and the app config panel share one set of components, section 5 of bootstrap5-theme.css, on Bootstrap cards and the dark set. Each page sets data-bs-theme="dark".
Component
Classes
Page
ref-page, width from --ref-width (1040px default; API 1150px, Network 800px)
Title
ref-head with h2 and a lead p in the first child, actions after it
Card
Bootstrap card, or card card-body for content. Radius, spacing and colours are set on .ref-page .card. open gives the accent border. Two cards side by side: row row-cols-1 row-cols-lg-2 g-3.
Card title
ref-card-title with a ref-icon
Section heading
ref-section holding an h4.ref-label, then a count or buttons
Label
ref-label, the uppercase grey label, also for sidebar groups
Icon circle
ref-icon, ref-icon-sm on rows. A state colour with bg-success-subtle text-success-emphasis and the like.
Row
ref-row in a card: icon, text, values, actions. is-link for rows that open in place. The open card gets open.
Code
ref-code for URLs, request bodies and responses
Tags
badge px-2 bg-*-subtle text-*-emphasis
Page CSS keeps what is particular to the page: the API sidebar, parameter grid and chevron (Lib/api_explorer.css), the WiFi signal bars and row parts (network_view.css), the feed grid and value cells of the config panel (appconf.css). A different colour set is made by overriding the --bs-* variables on a wrapper, as the setup wizard does with net-blue.
10. Apps
Apps share one kit, Modules/app/Views/css/app-kit.css, on the shared variables. Light and dark apps use the same card layout, from MyElectricFlow.
An app loads the kit with load_css, wraps its view (section#app-block, config and loader) in div.app-page and sets data-bs-theme="dark" or "light" on it. Light apps also load Lib/fonts/montserrat/montserrat.css, which the kit applies to a light .app-page. App specific CSS goes in a file beside the app. Light apps sit on the grey page background.
<div class="app-page" data-bs-theme="dark">
    <section id="app-block" style="display:none">
        <div class="app-card">
            <nav class="app-card-head">tabs, then app-card-tools: app-status, config nav</nav>
            <div class="app-live">label and value per item</div>
        <div class="app-card app-card-body">app-navbar, chart, app-legend</div>
        <div class="app-card app-card-body">app-card-caption, app-flow</div>
    </section>
    appconf include, ajax-loader
Component
Classes
Tabs
app-card-head holds a nav nav-underline of button.nav-link tabs (icon and label, accent underline when active)
Buttons
Text or toggle button: nav-link in a nav, underlined when active. Action: btn btn-outline-primary, active for the chosen option.
Energy colours
text-use, text-house, text-solar, text-wind, text-direct, text-import, text-export, text-battery. Bootstrap text-* classes keep their Bootstrap meaning.
Fields
input-group w-auto > input-group-text + form-select or form-control (width classes), a trailing input-group-text for a unit. form-check for a checkbox, small text-body-secondary for a note. .app-page .input-group has no bottom margin, so fields line up with buttons in a flex row.
Tables
table (table-sm for dense ones), col-primary for the name cell, app-swatch colour square
Option rows
app-option: checkbox and bold label, with fields (input-group) below when ticked. Rows stack with shared borders.
Card
app-card bordered block, app-card-body for padding. app-card-head header row with app-card-tools on the right.
Status
app-status > app-status-dot + app-status-text. is-live turns the dot green.
Live values
app-live row of equal columns, each app-live-label (uppercase) and app-live-value with power-unit or power-unit-static. Hidden items give their width to the rest. Three columns on narrow screens.
Chart toolbar
<?php include "Modules/app/Lib/timebar.php"; ?> in div#graph-nav.app-navbar, then Lib/timebar_manual.php after it. One app-timebar group as the graph module: range select.btn ($timebar_ranges to change the list), icon-resize-horizontal switch to Start and End fields (icon-ok back), zoom, pan and Now, then app-window-text. btn-group app-segmented for a two way toggle. Sprite icons switch to the white set inside a dark .app-page. JS in Lib/vis.helper.js: timebar_update(daily) after each draw, timebar_manual(cb) and timebar_now(cb) once, live_status_update(time) for the status, chart_legend(series) for a legend below the chart.
Legend
app-legend of app-legend-item, each an app-legend-swatch or app-legend-line and a label.
Caption
app-card-caption > app-section-label + app-caption-note
Line under a chart
app-card-caption app-chart-foot: window totals and a detail toggle, with a rule above
Category tiles
app-tiles of clickable items with active, each app-tile-title and app-tile-value
Option grid
app-options-label, then app-options of app-option rows in two columns. An open row (its *_options child shown) spans both.
Flow diagram
app-flow five column grid of app-flow-node (energy fill with statsbox-solar, -import, -battery, -house; app-flow-wide spans three) and app-flow-link (colour from --statsbox-color). Content: app-flow-name, app-flow-value, app-flow-unit, app-flow-title, app-flow-arrow.
Colours:
  • Surfaces, text, borders and accent come from the shared variables, plus --ec-app-panel-bg and --ec-app-box-bg.
  • Time bar blue: rgba(var(--ec-app-nav-rgb), a).
  • Energy colours: --ec-energy-* (see Colours and tokens). Chart series colours are set in each app’s JS.
Config panel: Lib/appconf, shared by every app and dark in all of them. Header with the app name and Launch app, readiness strip, App and About cards, feeds as two-column rows (status circle, key, node, AUTO, DERIVED or REQUIRED tag, click to edit in place), unused optional feeds behind a Show button, kWh flow feeds card, options as rows with switches, Manage rows. The first .lead paragraph of #appconf-description becomes the header line. Classes cfg-* in appconf.css.
Charts: Flot 5 legend panel and tick labels follow the mode inside .app-page. Tick labels are SVG text, so a font option needs fill. Unlabelled series need label: "" to stay out of the legend. Tooltip classes tooltip-title, tooltip-value and tooltip-units have fixed colours, as the tooltip is added to body.
11. Bootstrap build
Lib/bootstrap5/css/bootstrap.min.css is built from the Bootstrap 5.3.8 Sass by scripts/bootstrap5/build.mjs, then purged against the source of core and the modules. It is not the stock file.
  • Left out: navbar, accordion, breadcrumb, pagination, list group, toasts, popover, carousel, offcanvas and placeholders.
  • Included in full: the grid at every breakpoint and the utility families without breakpoint variants (d-*, flex-*, spacing, w-*, h-*, text-*, bg-*, border-* and similar).
  • Included when used: responsive utility variants such as d-md-flex, and the classes of each component.
A class that is not in the build has no style. After adding Bootstrap classes:
cd scripts/bootstrap5 && npm ci
node build.mjs --check  # classes used in the source but missing from the build
node build.mjs          # rebuild, then the same check
To use a left out component, uncomment it in scripts/bootstrap5/scss/bootstrap.scss and rebuild. Modules outside the emoncms repos are not scanned. If a class they use is missing, ask for it to be added to the build. See scripts/bootstrap5/README.md.
12. Planned
  • Glyphicons to SVG icons. Map each glyph name to an svg-icon-*, adding missing icons, then remove bootstrap2-icons.css and the sprites in Theme/img/. icon-white cases need a text colour instead.
  • Site wide light or dark mode as a user setting, set on <html>. Needs the remaining fixed colours in page CSS moved to variables. Largest first: demandshaper, timeofuse2, the profile app, graph view error and editor colours, device dialog, dashboard widget and editor CSS, autocomplete.css.
  • Inline style attributes and !important: tidy when a page is next changed.
  • Further work on bringing the different page family styles together into a unified style.
